The version field in the pim packet should be 2. Other version type is not supported.
Check the configuration on the neighboring switch. If they keep sending such packets, this wswitch may not be able to interoperate.
Warning
%vlan0% version unsuported for pim message. Invalid version given %num0%, message type %num1%
| Name | Type |
| vlan0 | VLAN |
| num0 | sInt |
| num1 | sInt |
